Counter Rotating Engine >
Old 04-17-2017 | 04:46 PM
Default Counter Rotating Engine
Any reason not to buy a boat with a counter rotating 572 bbc? It is required on this boat due to an arneson drive. I don't have a good reason but it feels like a red flag to me, but as I understand it the only difference is a the cam gear setup, starter, and firing order. Do they sound any different running? Probably a stupid question but it just seems so unnatural.
rob vanharten is offline
Old 04-17-2017 | 05:32 PM
Team Archer's Avatar
A lot of old boats ran opposite rotation motors. Most all twin engine inboard boats ran them. The Gentry 4 engine cat had 2 engines run LH and 2 engines run RH they were tied together thru a gear box 2 engines to 1 prop they ran great.
Team Archer is offline
Old 04-17-2017 | 05:41 PM
the one possible issue is the cam itself. it isn't a standard off the shelf opp rotation 350 horse cam, so it would probably have to be custom ground. the engine torques will cancel each other out, which is a good thing.
dereknkathy is offline
Old 04-18-2017 | 05:55 AM
been running one for years, they way its reversed makes a difference, in old mark IV BB's they ran a gear to gear so cam/dist run std, works fine, with Gen VI there is no room(they say) for this, they put a reverse cut gear on cam and dist, issue is it now reverse's the load on the dist, std will dist will eat themselves up in no time...mine ate about 5 before figured out WTF. As of now they make a GM EST that is modded with a extra bearing the top and works fine.
ezstriper is offline
Old 04-19-2017 | 05:42 PM
I have a reverse 2 piece crank with a gear, not sprocket on it. The reverse motor in my hatteras also has standard dist rotation. So I am sure gear drive works on rev rotation Mk 4's.
Old 04-21-2017 | 05:45 AM
all dist's have to run std rotation as they drive the oil pump..
Old 04-27-2017 | 02:55 PM
In a reverse rotation application, the standard rod pin oil breakout location would be close to where the rod bearing is supporting combustion load, and would reduce oil flow to the rod bearing. Are the crankshaft oil drillings different in reverse rotation engines?
NautiSouth is offline
Old 04-27-2017 | 05:10 PM
the same crank. same oil drillings.
Old 04-27-2017 | 05:23 PM
Well that's less than ideal. Glad to hear it works, though
Old 04-28-2017 | 05:47 AM
some have experimented with flipping the pistons around(notch to the rear) seen both ways, just tore down a merc 5.7 and they were swapped, but all the cranks/rods/pistons are the same, they do make special rear main and front cover seals that are reversed
