Stock Fuel/Water separator hp limit >
Old 04-24-2017 | 06:29 AM
Default Stock Fuel/Water separator hp limit
I'm thinking about replacing the stock fuel water separators in my boat. I was shocked to see that they are only 1/4" npt, I believe when I discussed this with Dave Weseldyk (yes I know I really messed up his last name), he said the stock fuel system is good up to 600 hp. Has anyone else tested the limits of this this part? I should be in the 650-670 range, so I think I should at least think about replacing this. Also does anyone know what the flow limit is on the stock filter?
endeavour32 is offline
Old 04-24-2017 | 07:30 AM
I would think 600hp is highly optimistic...but thats me, I did away with mine totally, also changed the tank outlet, was running little over 700 with a procharged setup(both carb and EFI) and never had a issue. But 1/4 I saw as well and thought even mild street stuff gets 3/8, I would think 450hp...
ezstriper is offline
Old 04-24-2017 | 07:42 AM
Yeah- I was really shocked last night when I pulled the old fitting and saw it was 1/4" npt. I was like WTH.
Old 04-28-2017 | 08:06 PM
Hang Time 27's Avatar
I used a housing meant for a diesel - less expensive than the "high performance" ones yet with the same larger ports - been to many years now, so I forget from where....
Hang Time 27 is offline
Old 04-28-2017 | 08:09 PM
I ended up buying the Hardin Marine filter heads. With the filter, they were $89 ea. Not the cheapest option, but a lot cheaper than the Teagues which look like the same unit, and they didn't include the filters.
Old 04-28-2017 | 08:20 PM
SB
Perma-cool ? I've used them. 1/2" ports.
SB is offline
Old 04-29-2017 | 09:33 AM
This is the filter I use and have room for on my stock 502 mpi mags. It fits the stock filter head and filters much better than the short 25 micron ones.
https://www.mercurymarine.com/en/us/...are/fuel-care/
johnny b good is offline
Old 04-29-2017 | 10:31 AM
vintage chromoly's Avatar
https://www.fstperformance.com/rpm500
This is the one I'm using. Not cheap, but neither is my engine.
-12 O- ring ports
vintage chromoly is offline
Old 05-02-2017 | 04:49 PM
-12 O- ring ports
Hardin has filter heads that use the same filter for half the price. 1/2" NPT though so I think a bit smaller than -12 AN? The FST filter is a good performance filter. http://www.hardin-marine.com/p-74301...d-bracket.aspx
jerm324 is offline
Old 05-02-2017 | 04:54 PM
SB
I pump my fuel thru the fuel/water seperator filter vs 'suck it' through. That increases the volume any filter and head will flow.
SB is offline
