Originally Posted by 800XCR
(Post 4550729)
It seems there are claims of being able to run those rpm's, but I have not yet been able to get confirmation or the amount of lift. I currently run solids that are due for a change and just thought I'd see if I could find someone with first hand experience.
Thanks but to answer your question on high rpm hydraulic vs solid roller tappets, Lunati has the tappet for that |
Originally Posted by adk61
(Post 4562657)
High RPM Hydraulic Roller Lifters - Lunati Power... these will run high rpm without incident.. 7000 isn't unheard of.. open your wallet
Short bursts, you can get away with a lot.
And as far as 7,000 rpm, I would assume you are talking about relatively short runs (30 seconds or less). Running a constant-load at 7,000 rpm in a performance boat application requires VERY substantial components. I would stay under 6,000 with hydraulics. 7,000 screams SOLID to me. Just my 2 cents. MC |
i run my SC 565 to 7000+ almost every time out for short bursts. using Morel .903 hydraulic lifters. cam is ,680/.690 @ 256 and 264 @ .050. i do have Jesel shaft pro rockers. never run sustained high rpm for long because of accelerated wear. rebuild engine every other season, about 110-120 hrs.
I'm perfectly happy occasionally adjusting lash and visually inspecting my setup VS dropping $1k on hydraulic specialty lifters and trusting the gods at 7,200rpm.
BBC valvetrain is not particularly stable at 7k+ unless a LOT of money is spent on girdling or shaft mounted rockers. I regularly have to weld up and remachine BBC race heads that have suffered bent/pulled out studs/broken stud bosses, etc. I did a set of ProLine heads last fall that had 2 completely broken out bosses on one side and 3 on the other and this motor ran full girdles as well. Hydraulic lifters are a "convenience item" in my book. They allow you to skip maintenance intervals by adjusting to accomodate wear/thermal expansions and DAMAGE to the components. I like to check lash and SEE everything. Check stuff. When ONE has more (or less) lash than the others, it is a CLEAR INDICATION that you have an issue to search out. Hydraulics hide these issues until they become nasty. You guys do what you want to do. If I'm spinning a stud-rocker BBC 7000+ then I'm runnning solids, I'm checking them on a regular basis. Spend the money you'd pay for a set of $1,000 Morels on some valve covers with removable lids. m |
| All times are GMT -5. The time now is 01:48 PM. |
