Playboy getting Head
3 Attachment(s)
Had the pickup tube in the oil pan loosen up so I had to pull the engines out of the Bunny Lounge. So I decided to add some upgrades while they are out. Including some New Heads, Through Honed Extruded Intakes, CAM. I was running about 570 HP, before out of the 500EFI's. Just wanted everything to be freshened up and know where everything was at. Only draw back is that I wish I knew the situation in the Fall versus the Spring, but seems like it will work out. Looking forward to some other updates while in the process too.
Figured I would share some of the build since I am working with some of the OSO members. |
3 Attachment(s)
Pulled the engines out at my buddy's Jason Shop. I unbolted everything and he was nice enough to use his Telehandler to pull them out. Loaded them up in the Dually!
I ordered a set of Big Al's Promax 317 Heads for the build about a month ago, he is waiting for castings, but assures me that I am first on list once the castings make it to the shop. According to him, he is expecting a shipment soon...like next week. I will provide some pictures when I get them from him as he does his completion of the heads. I decided that the best upgrade is to ditch the GM heads. I will share the Flow Numbers for others once I get them finished from AL.
I am also working on CAM selection....which is always a Hot Topic....lol . Eddie Young,will be doing the Final Tuning on the engines when I bring them down to Tenn. He is selecting the custom CAMs and I am going with Johnson lifters to work with the CAM Profile. Should be pretty Sweet. However as you guys know with any of these projects. The Rabbit Hole gets bigger and bigger.......But that's boating.
Jay Baker in Upstate NY is doing the assembly. Top Notch and great to work with. All working together to get a final product and hopefully meet the final goals. |
I had a bunch of $$ offers for the boat in the past year, 35TS are still popular and the Playboy version is just on the cool side especially the Black and White original. But since my wife and I love the boat, it runs in the mid 80's mph and I purchased a new trailer, we decided to keep it. Now we are going to upgrade it a little more. I can't seem to leave things alone. lol
Looking forward to seeing and hearing the motors at the Battleship Run.
Padraig |
Al from AK Racing Performance has been great to work with. Always there to answer questions. He has been in contact with my builder. We just finished up and got on the same page of what we are looking at for installed height and seat pressures for my application. Al also told me that he personally contacted the castings distributor to try speed up delivery of the heads so he can get the ready to bolt on complete heads done. I have everything else ordered and machine work is being done now. At least I know with Al's heads, and now that he has the final specs, they will be ready to TRULY bolt on and be ready to go and make power/flow. That is piece of mind when buying heads.
Final Chamber size from Al is 121cc Install Height 1.900" 140-150 lbs of seat pressure 400-420 lbs open pressure Matched for the CAM and Johnson Lifters |
this is going to be a great build... once done I'm sure it will be a real head turner!!! NO PHUN INTENDED!! :Score-101010:
Good choice on the Johnson lifters... I like and use these without issue
Love it! love that boat too!!
very cool boat - good luck with the build!
Sounds awesome man. Can't wait to see results.
Thanks, these projects tend to grow....rather then shrink....lol
Originally Posted by cigrocket
(Post 4551623)
How many Playboy Cigs were built? That is my dream boat....
Originally Posted by TylerBurich
(Post 4551947)
Some good info |
Machine work being done, parts, parts, and more parts ordered. Waiting on Castings of heads from distributor to Al's shop so he can work his magic on the Promax 317. Things are taking shape, and everyone involved is on the same page.
Good luck on the build! Love the title of this post.... :cool-smiley-011:
2 Attachment(s)
Originally Posted by Nuke427
(Post 4553125)
Heads are in, and Big Al is working his magic. I will be posting some preliminary pictures soon. They look awesome
5 Attachment(s)
Some progress on the heads
we be rockin and rollin on these badboys!!! Playboy's gettin head alright!!! :lolhit:
3 Attachment(s)
Waiting on some parts from Eddie Young and also Al working on the heads.
My Wife de- greased the bilge, roughed it up with 180 grit and put down 2 coats of paint. Looking good. |
Looks great. What paint did you use in the bilge?
Originally Posted by I.C.U.Lookin
(Post 4554760)
Last Boat I had...the Top Gun...I used Bilge Coat, I found that it turned yellow and faded pretty fast and despite good prep seemed to take forever to cure The Mistress I had, I did Red in Awlgrip, It was harder to work with and on the Spendy Side. So we shall see. The white is nice and bright, and that is what I like, it was easy to apply and flowed really nice. I tend to keep a really clean bilge so I assume it will hold up well. I mixed up a 1/2 quart at a time with the hardener. So far I am pleased, but I guess time will tell. The prep was Cleaned Bilge with Purple Industrial Degreaser from Tractor Supply with a pump sprayer. Power Washed. Then Light sanding with flexible sanding blocks 180 grit. Finally wiped everything down again with acetone and tac cloths. Applied the Rustoleum Bright White. Brush and Small Roller. |
(Post 4554729)
My Wife de- greased the bilge, roughed it up with 180 grit and put down 2 coats of paint. Looking good. Don't forget to register for the Battleship, discounted registration is coming to a close. The wife just did ours. Padraig |
Originally Posted by Padraig
(Post 4554767)
Can't go wrong with Eddie Young. What is he supplying?
Don't forget to register for the Battleship, discounted registration is coming to a close. The wife just did ours. Padraig I will be going to Battleship run, Hopefully boat will be done or I will be hitching a ride |
(Post 4554769)
I am getting CAMS and LIFTERS from him... He is also doing the EFI TUNE and DYNO. I will be venturing down to TENN.
I will be going to Battleship run, Hopefully boat will be done or I will be hitching a ride Padraig |
Is there an ETA on these engines? As always, I commend you on the wife pic!
Spoke with Big Al yesterday on the phone, he is performing the final hand porting and assembly. The Heads are scheduled to be done this week!. Can't wait to see them!
9 Attachment(s)
Heads getting final hand porting and polish along with some engraving. Al is wrapping them up as we speak and getting ready to ship. He will be giving me some flow numbers, and when I get them I will post them for ya!
Looking to be shipped out FRIDAY!. Can't Wait!
1.900" installed height
140-150lbs of seat pressure 400-420lbs open pressure Matched with the CAMS Eddie Young Picked out along with the Lifters. Trying to keep it simple |
Heads are done, Al has the Flow Numbers.....I will be sharing them. Al has been awesome to deal with, he even arranged the shipping and got a broker to handle the customs border. All I can say that I have dealt with many different marine businesses throughout the last 20 years of boating and all I can say is Big Al has gone beyond my expectations in terms of getting the product done, working with my builder, answering questions, asking questions and most importantly answering the phone and even contacting me after hours or the weekend. TOP NOTCH ALL THE WAY.....Now the proof will be in the pudding once the heads are on the new builds. I am sure they will make the target power!!
Good to hear things are moving along.
What springs and valves are being used ? |
Ferrea 2.300 Stainless intakes and Ferrea 1.900 Super Alloy (Inconel) exhaust.. Comp Cams 929 installed as per customer's request, based on the info provided by his builder
SB have you laid eyes on the 317's yet? I am happy with how they work and equally as important the level of customer service I, as a distributor get from them...
as Kurt stated "the proof is in the pudding" my reply is bring a hearty appetite as the pudding is YUMMY!!! |
as promised... here's the data
intake exhaust cfm .100 - 91 .100 - 81 .200 - 172 .200 - 144 .300 - 260 .300 - 190 .400 - 318 .400 - 235 .500 - 360 .500 - 265 .600 - 382 .600 - 286 .700 - 394 .700 - 302 .800 - 401 .800 - 305 exhaust with stubby pipe... would get an slight increase using a 2.5" x 12" 90 degree bent pipe... didn't have it at this time... thank you Kurt for the kind words, it's been a pleasure doing your heads... Solid guy right here!! |
Heads on my doorstep as promised by Big Al. Wrapped up really great and shipped via FEDEX. Can't wait to get everything together and get the Engines down to Eddie Young for DYNO days. Waiting on a few more parts to make it happen. Guess its a good year for it since the water is high and its been raining and unusually cool up to this point in the season.
Well, a few parts delivered wrong and had to wait on a few custom parts. But the Engines are done! Finished up last week. Now waiting on Eddie Young to Dyno Tune. Trying to schedule drive to Tennessee. I want to salvage half of boating season
| All times are GMT -5. The time now is 09:15 PM. |
