Backfiring through intake >
Old 05-16-2017 | 06:39 PM
Originally Posted by dereknkathy
I would take a shot at freeing up the valve and doing a compression test.
Pushrod is bent. couple of valves shot. sending to machine shop to have work done and heads cleaned. Also going to go ahead and get new manifolds & risers for both engines. Turns out one of the manifolds was leaking which is the root cause of all this. Live and learn.
Blown284 is offline
Old 05-16-2017 | 06:47 PM
SB
Salt water ?
SB is offline
Old 05-17-2017 | 08:10 AM
Which manifold? Gil style? I believe the risers, being stainless, have very long lives. The manifolds are the culprit.
dereknkathy is offline
Old 05-17-2017 | 08:55 AM
=Blown284;4554613]Pushrod is bent. couple of valves shot. sending to machine shop to have work done and heads cleaned. Also going to go ahead and get new manifolds & risers for both engines. Turns out one of the manifolds was leaking which is the root cause of all this. Live and learn.[/QUOTE]
Good idea, don't patch it up,,send to the machine shop and get it fixed properly .,save a lot of problems later on.
253 is offline
Old 05-21-2017 | 05:55 PM
Originally Posted by SB
Salt water ?
Yep.
Blown284 is offline
Old 05-21-2017 | 05:56 PM
Stock mercruiser style... not stainless.
Blown284 is offline
Old 05-21-2017 | 06:10 PM
Ok, then look on ebay for stainless risers that fit stock manifolds.http://m.ebay.com/itm/816900A7-Stain...%257Ciid%253A1 you can usually find en about 150 a pair.
