Are these Merc Gear Lubes the same?
Mercury High Performance Gear Lube is part number 92-858064K01 and is different than the ones you have shown here. It's a straight SAE 90 weight. That's what you should be using.
Edit: The SAE 90 product is what I used to use. I see now that Mercury has a Extreme Performance Racing lube that is 85w90; I assume that's what you're showing here. I now don't use either of those. I use Torco RTF.
Unless they changed the name, the Quicksilver good stuff was labeled High Performance Gear Lube. And typically, my local Walmart carries it and has the best price around $11-$12. I also want to say the color is different between the regular QS gear lube and high performance.
I was just discussing this with the guy who services my drives. He was a staunch advocate of Torco RTF in #6 drives and recommended I switch to it last year because he felt it was better than the HP gear lube (SAE90). I had very good results with it albeit it is expensive and requires changing at a more frequent interval than the Merc. stuff. He told me this morning that Merc. reformulated their gear lube to the one mentioned above and now he recommends I switch to it over the Torco as it was targeted specifically for Bravo drives. FWIW.
There is a difference between the High Performance Quicksilver and Extreme Performance Quicksilver, consider it medium duty and heavy duty. In the past, the item #s were just one letter different from comparable oil\lube when comparing Quicksilver and Merc Race. Now Merc Race uses totally different item #s for the comparable Quicksilver/Merc Race throwing a wrench into everyones trained way of thinking.
I would go with the Quicksilver Extreme Performance for the XZ, If I had the XZ drive I would want what is the best from Merc. Remember, currently the High Performance is the "Standard" lube, not for XRs, 6s, etc
What you have is the old for standard outdrives. The equivalent to that now is High Performance Quicksilver but that or the 90 w is only recommended for standard medium duty outdrives.. I'm surprised you would run that in an XR. Extreme Performance Quicksilver is designed for XRs, 6s, etc.
I miss read your previous post, QS extreme it is.......part# for this ?
