SSM 3 what tranny to use >
Old 06-08-2017 | 10:11 AM
A rubber mallet . That shaft is just an extension that is slid over the splines on the trans main shaft. Back when i did this swap, it took about 20 minutes removing the trs tailstick, trs coupler shaft, and installing ssm coupler shaft and tailstock.
MILD THUNDER is offline
Old 06-08-2017 | 11:26 AM
Ooohh I love OSO..big smile and thanks..will try that first thing in the morning..let you know..
b regards
Leif
leif is offline
Old 06-08-2017 | 11:46 AM
northernoffshore's Avatar
http://www.offshoreonly.com/forums/s...ine-drive.html
northernoffshore is offline
Old 06-08-2017 | 12:17 PM
stuff like that doesn't show in the manual since it wasn't TRS specific. so, one could also put these shaft extensions and housings on a shaft boat borg?
dereknkathy is offline
Old 06-08-2017 | 12:28 PM
take the short tail off the doner trans.. including the bearing and shaft assembly, also remove same from TRS use the gasket Joe mentioned and reinstall the short (#3) tail shaft and bearing into the cover then install onto transmission... not a difficult job, just make sure splines line up and gasket surfaces are clean...
adk61 is offline
