25w50
Old 05-18-2017 | 11:54 PM
BUP
Originally Posted by SB
I have a list of MSDS sheets of many of Merc's products which show the manufacturer
I posted this elsewhere:
Some of those changed currently as that was 10 years ago. Merc now makes it a point to have their name on the MSDS sheets without listing the true manu.
BUP is offline
Old 05-19-2017 | 12:05 AM
BUP
http://www.kelloggmarine.com/msds/ME...oncentrate.pdf
BUP is offline
Old 05-19-2017 | 12:11 AM
BUP
Got to love the snake oils and all the alcohol in the gas additives -- many OEM marine fuel additives contain a from of alcohol. Merc above MSDS has ---- Isopropanol in the mix is the main component 95 %
https://www.reference.com/science/is...59c654aac896eb
BUP is offline
Old 05-19-2017 | 05:12 AM
Great what happen to the calls for Valvoline VR1 20w-50 Racing oil..... now I am going to have drain my engines and put something else in them. Drain my outdrives because that changed too quicksilver gear lube is no longer the good stuff and now thanks to BUP I have to drain my fuel tank that I just filled up because of an addtive I put in it. Next winter I am just going ot leave everything emtpy until spring when you guys make up your minds on what I should be running. Thinking that might save me a few coins in spring of 2018.
One thing I didn't think of until now is I have Mobile one filters and Valvoline oil in my motors I better get those filters changed (probably to Fram) because I am sure Mobile and Valvoline are not compatible.
Questofpower is offline
Old 05-19-2017 | 05:45 AM
SB
Originally Posted by ICDEDPPL
Since we know 25w50 is 50 weight at 212* The question is what is viscosity at 180* where most of us run . Probably less that 50weight .
So if I want 50 weight protection the only way would be to use a straight 50 weight oil. Right? Otherwise at lower temps it could be 30weight..
Here:
http://www.kewengineering.co.uk/Auto..._explained.htm
SB is offline
Old 05-19-2017 | 06:01 AM
Originally Posted by benjen
Haha. Your cricket needs to be a bit more specific than that.........FLOW RATES doesn't answer the question as to what the weight of the oil is at 180 degrees.
I use what works.even if I only change it 2 or 3 times in a decade.
sutphen 30 is offline
Old 05-19-2017 | 06:12 AM
I think its more of a viscosity vs temperature thing. Cooler the temperature, higher the viscosity.
The viscosities at 104*
15w50 mobil = 125 CST
5w50 mobil = 108 CST
10w30 = 77 CST
20w50 = 181 CST
straight 40 = 136 CST
straight 50 = 219 CST
At 212*
15w50 mobil -= 18 CST
5w50 mobil = 17.5 CST
10w30 = 11.5 CST
20w50 = 20.5 CST
straight 40 = 14.5 CST
straight 50 = 20.0 CST
Pour points.
10w30 = -27.4* F
Straight 40 = -16.6 * F
Straight 50 = -0.4 * F
20w50 = -11* F
A straight 40 grade oil, has less viscosity at 104* temp, than a 20w50 , and pours to a colder temperature, than a 20w50? Mobils 15w50, seems to have ALOT less viscosity at 104*, than a VR1 20w50.
MILD THUNDER is offline
Old 05-19-2017 | 06:17 AM
SB
You use Mobil 1 Vtwin - it is loaded hard with phosphorus and zinc. It is also designed for engines (Harley of course) that are air cooled and thus encounter major oil temps.
Go to the bottom of: https://mobiloil.com/~/media/amer/us...pecs-guide.pdf
SB is offline
Old 05-19-2017 | 09:47 AM
BUP
Don't kill the messenger for the fuel adds. There is one on the market that is straight ethanol and they use to market very heavily on the marine side. Yamaha branded fuel adds all went to non alcohol base products for the fuel systems. It has been known for the last 20 years that many fuel adds for the marine side was mostly alcohol based.
BUP is offline
Old 05-19-2017 | 10:46 AM
BUP
Maybe a good read for some and as I said before about inexpensive off the self diesel oils. Would not use them in a marine app currently. Their ZDDP levels have fallen greatly.
Just adding --- The 3.0 - 4 banger marine side still used Flat tappets and I can not tell you how many times I seen bad lobes on their camshafts from owners doing their own changes, Buying EPA mandated auto oils off the shelf.
FWIW below
http://www.enginebuildermag.com/2017...84&bid=1760177
BUP is offline
