Pressure relief valve...how do you set it? >
Old 05-20-2017 | 10:31 AM
  #31
Originally Posted by benjen
Color me stupid. If the water coming out of the chiller goes overboard, as I suspect it does what is the regulator doing after the chiller?
Regulated leak in the system.
Unlimited jd is offline
Old 05-22-2017 | 04:23 AM
  #32
I just added pressure relief valves to my set up. I went with the Hardin valves that are incorporated into the thru-hull fitting, they are preset at 10 lbs. Mine is in an NA application and are mounted between the oil cooler and the engine. I've yet to run them, so no clue what the actual pressure is.
endeavour32 is offline
