Best oil for 509 mercruiser supercharged mild build 787 hp? >
Old 05-18-2017, 06:09 PM
Originally Posted by Checkmate787hp
It has the k&n oil filter....I'm more trying to figure out to stay with a 10w 40 or go to a 20w 50
What oil temps do you see?
MILD THUNDER is offline
Old 05-18-2017, 06:18 PM
SB
Received 3,117 Likes on 1,403 Posts
800hp is mild ? Don't let that fool you into running low weight oils.
SB is offline
Old 05-18-2017, 07:19 PM
Received 1,493 Likes on 807 Posts
I mean I'm not racing this boat or beating the snot out of it....it's more of cruising on my lake with the occasional wide open run..... and a few times this summer to big water and ocean...
Right...
getrdunn is offline
Old 05-18-2017, 07:57 PM
I ment that it's a mild build.....only 4.5lbs of boost....but I'm seeing oil temp of 140 deg....maybe 150 max...if I should be running 50 instead of 40 I will do it....just cuious of how big the difference is between the 40 and the 50 weight.....my lake isn't big enough to run this boat WOT fully trimmed....dyno sheet shows 5900rpm 787 hp.....ive seen about 5400 86mph....if I could beat the bag out of this boat everytime I would but realistically I'm not beating the tits off her every ride
Checkmate787hp is offline
Old 05-18-2017, 09:59 PM
You sure that's not water temps? Are you running oil t-stat? If not you should although given circumstances I can see where it would be difficult to build temps. Given those temps assuming you have t-stats I'd say stay with a lighter weight oil.
getrdunn is offline
Old 05-19-2017, 07:17 AM
Oil temp is usually close to the same as water temps....motor does not seem to get that hot....not sure if there is an oil thermostat....I'll have to check
Old 05-19-2017, 09:38 AM
swan2's Avatar
My oil temps are no where near the same as my water temp!! Are you sure that correct because if thats true mine must be all kinds of jacked up lol.
swan2 is offline
Old 05-19-2017, 10:24 AM
Any condensation under the oil fill cap?
Baja Rooster is offline
Old 05-19-2017, 11:15 AM
Pretty sure....I will double check next time I'm out
Old 05-19-2017, 11:16 AM
Actually yah there is....
