Yearly maintenance, and switching to synthetic >
Old 05-22-2017 | 10:33 AM
SB
If your a big guy like many of us and your engine compartment is very cramped, it can take you 2 hrs just to get yourself back out of the bilge.
SB is offline
Old 05-22-2017 | 10:40 AM
HA, well I did experience that with the drain plugs, I felt like I had to do a handstand to get those things in and out. The accessories on this are fairly easy to reach though, shouldn't be too bad.
MTScott is offline
Old 05-22-2017 | 11:46 AM
One of the local dealers had an impeller kit, hopefully the housing is in decent shape. The guy at the parts counter told me I could just lubricate it with dish soap when I installed it.... does that sound right?
MTScott is offline
Old 05-22-2017 | 12:12 PM
Yes
oconnor marine is offline
Old 05-22-2017 | 12:13 PM
SB
If the impellar is missing pieces you need to go find them. Typical places are in the inlet to the coolers. ie:stuck in frt of the small tubes.
SB is offline
Old 05-22-2017 | 02:14 PM
When you change your oil for seasonal layup, make sure you start and run the engine for a bit.
If you don't the only part of the engine that receives the benefits of new oil is the pan.
Ken
minxguy is offline
Old 05-22-2017 | 02:21 PM
OIl every year(VR1), impeller every 5 or more. One lasted over 20 yrs and 2000 hours..They are not as wimpy as most think.
Pismo10 is offline
Old 05-22-2017 | 02:35 PM
SB
^^^^Yup, have a few boats here that are on original impellars. One's a 1994 and the other I believe is a 1990 ? Known the boats since new. I ask every spring and I keep getting the old 'temp is fine, don't worry about' answer. LOL.
SB is offline
Old 05-22-2017 | 03:06 PM
On Time's Avatar
My 3 boats get new impellers every 2 years. I have a box of "like new" impellers for all 3. Just in case I ever need one...
I use Mercruiser semi syn 25W-40 in the 4 cycle engines changed 25 hrs for the 525s and 50 hrs for the 350 mag. Mercury Premium Plus semi syn outboard oil in the 2 cycles. No oil problem. Ever.
Mercury High Performance gear lube in all 5 outdrives annually.
Hours range from 270 to 340 on the inboards and 500 on the outboards. No service issues on engines or outdrives.
On Time is offline
Old 05-23-2017 | 07:51 AM
Well, here is what is left of my impeller:
MTScott is offline
