Gil exhaust bolts >
Gil exhaust bolts
Gil exhaust bolts
Old 05-22-2017 | 02:27 PM
Default Gil exhaust bolts
Does anyone know where to order or exactly what size would work with these? I know a standard header bolt won't work. Anyone have a part number handy?
Crude Intentions is offline
Old 05-22-2017 | 03:29 PM
I bought this set from Hardin 420-906211.
DanWentworth is offline
Old 05-22-2017 | 05:51 PM
Thanks.
Old 05-22-2017 | 06:32 PM
why not measure the bolt holes,add 1/2" and order from macmaster-carr.get some nice stainless bolts and washers.
sutphen 30 is offline
Old 05-22-2017 | 08:07 PM
We use SS studs on our Custom Marine exhaust. Studs are easier than fighting with bolts. ARP is an option or http://www.kelkoproducts.com/stud-bolts.html.
BenPerfected is offline
Old 05-22-2017 | 09:11 PM
I do the same on my stellings headers. well, four studs per side, since the way the pipes sweep, I still need bolts on the other half. But, when installing those heavy old headers, the studs are nice!
MILD THUNDER is offline
Old 05-22-2017 | 09:32 PM
With Gil's you'll never be able to get the center ones out using studs. I get stainless socket head cap screws from a local fastener supply. About $12 for 16 long, 16 short and 32 washers.
Unlimited jd is offline
Old 05-23-2017 | 05:56 AM
yup,,I use 2 studs/ manifold on the short bolt holes,even on my set up,which is fairly tight in the center,I can install the manifolds.no more blown out/ripped exhaust gaskets anymore.
