props
Old 05-24-2017 | 05:24 PM
Default props
I have a 1995 35 foot fountain with bravo ones. I put a pair of spare props I bought with the boat. I put right prop on starboard side and left prop on port side , had to put boat in reverse to go forward. do fountain prop run different directions?
ninjaturtle is offline
Old 05-25-2017 | 05:47 AM
Ayuh,.... With Bravo drives, direction can be reversed, by switchin' the shiftin',...
Bondo is offline
Old 05-25-2017 | 06:19 AM
Most fountains are set up to turn in. If you switch props, lh on stbd drive an rh on port drive it will shift correctly. If you want to spin them out then the shifters need to be reconfigured
Mr Maine is offline
Old 05-25-2017 | 01:08 PM
Switch sides and it works like normal, Thank you.
Old 05-25-2017 | 03:38 PM
A little bit of an OH SH!T moment when you put it gear the first time I'll bet...
dereknkathy is offline
Old 05-25-2017 | 05:44 PM
Yes it was when I was on 5 feet from a concrete pier when I put it in gear.
