Measuring Dry Exhaust
So they are standard width, what about how far above the gimbal stud line like in reference A ?
SM didn't give you a spec sheet like what Lightning has to measure to/from/where ? Like this
http://www.cpperformance.com/instruc...mtailpipes.pdf
When I measured for my Lightnings I bought new, I had to measure the standard stuff (A & B) in the link that was posted above and how far through the transom I wanted the tips to stick out.
hope this shows up.
It didnt move becuase cause we screwed togather but just in case marked across everything. Also marked where we wanted hose bib.
https://flic.kr/p/U4sYrW
Another question. My current setup with the cmi e tops has 2 hoses that run from the engine
1. Bypass to the collector
2. T stat to the manifold
what is everyone doing for plumbing routing on the stainless marine as there is only one location for plumbing. I was thinking about joining the two together via a fitting then sending it all to the manifold. The other option is adding an additional bung to the riser/tail.
Wow
