Milkshake on rebuilt engine >
Old 06-27-2017 | 10:25 PM
  #101
.008 isn't enough to mess up that angle.. 060 thick intake gasket. If you you felpro composite fiber, it will compress. I never use the permatorque style on intakes. They don't conform easily
veloc410 is offline
Old 06-28-2017 | 07:49 AM
  #102
Default Cabin fever
I checked my engine on the stand last night with feeler gage. There are gaps that you can get feeler gage into all the way around the head and easily accessible gaps on each end of head. My engine is between. 039 and.040 all the way around tighter at one end than the other. Same on both heads. There are small gaps you can get feeler gage towards the outside of block and on the valley side also but intake would have to come off. No paint on my heads yet. Should be enough gaps available to squeeze some shim into on yours also. Did you say your heads were pressure tested,????
veloc410 is offline
Old 06-28-2017 | 08:18 AM
  #103
Veloc, do you mean you can get a feeler gauge to go between head and block till it hits the head gasket? Cuz if you can get .001 to go between gasket and either, you are in worse shape than fever...
dereknkathy is offline
Old 06-28-2017 | 08:22 AM
  #104
Yes between head and block. They are felpro 1047 marine gaskets. I figured the gasket isn't exactly the same end to end. But now that you mentioned it I'm going to check with. 001 right now
veloc410 is offline
Old 06-28-2017 | 08:51 AM
  #105
Just so you PPL know the 1047 gasket is actually 17048 part # stamped on gasket. It checks out. . 001 will not go in anywhere. I measured my old gaskets that have like 4 hrs on them. The measure. 0435 at one end and. 0425 at other. Obviously compress down to.. 039
veloc410 is offline
Old 06-28-2017 | 09:08 AM
  #106
I am interested in this post because I had some water in both of my engines no where near that bad. I thought condensation because of 140 t stat and large oil cooler but not sure. Any way just as worried as cabin is and hate to this **** happen to anyone it sucks.
veloc410 is offline
Old 06-28-2017 | 09:30 AM
  #107
If oil never hits 210 and stays a while, what little water gets in will never boil out.
Old 06-28-2017 | 09:48 AM
  #108
I agree completely with you
veloc410 is offline
Old 06-28-2017 | 09:55 AM
  #109
Im still trying to decide what im going to do. I didnt sleep at all last night thinking about this chit show.
Im tempted to yank the intake. It will need to come off anyway. I might pull the plugs and pressure test again
i might drive it off a cliff set fire to it and get drunk.
cabin fever is offline
Old 06-28-2017 | 09:57 AM
  #110
SB
Who's been putting the intake on - you or him ?
SB is offline
