Milkshake on rebuilt engine >
Old 06-29-2017 | 06:41 PM
  #151
But it's so shiny and pretty...
dereknkathy is offline
Old 06-29-2017 | 07:59 PM
  #152
Tinkerer's Avatar
Veloc - He hasn't run the engine yet since he got it back from the builder. IF the bolts are too long by just a little you wouldn't get the proper clamping force by justenough to make it leak.
Tinkerer is offline
Old 06-29-2017 | 08:03 PM
  #153
I agree with you whole heartedly. I'm very interested to see what they and definitely want to hear that he is up and running without issues
veloc410 is offline
Old 06-29-2017 | 08:07 PM
  #154
What an ordeal, right I posted pan to show how I had to cut tabs. He mentioned earlier that he thinks builder left pan out this time around. They aren't needed for single plane manifolds like ours.
veloc410 is offline
Old 06-29-2017 | 08:16 PM
  #155
By the way I have 2 Original 540 bulldog rotating assemblies, neutral balance. Manley h beam rods, wiseco pistons, lunati 4.375 cranks. I was thinking bout keeping them but not sure.
veloc410 is offline
Old 06-29-2017 | 09:56 PM
  #156
Thanks guys. Builder is handeling it from here. Other then the fact its happening i cant really say anything negative about the builder. unfortunatley he wants to motor out which sucks but in less then 2 hrs ill have it sitting on the stand in my truck.
Ill report back when i hear what the issue is. And no,it will NOT go back in till i know for sure 100% its fixed
cabin fever is offline
Old 07-05-2017 | 04:50 PM
  #157
Default Update
Motor got dropped off monday morning. He just texted me a picture of him checking heads. The intake is off. He has it pumped up to 15# and its been holding for 2 hrs. Hes gonna let it sit overnight and check again
seeing as it wouldnt hold for 2 min for me im gonna go ahead and assume i have an intake issue
either the manifold itself is bad (freshwater only. (Aluminum dart intake)
there was a gasket issue with the manifold
or i had something wasnt sealed when i was checking it. I was spraying soapy water around looking fir bubbles and never did find anything.
Inwould imagine i could check the intake by itself somehow?
Old 07-05-2017 | 05:06 PM
  #158
You could fab intake block-off plates from wood and bolt them on over the water jackets. Would only need on the front unless it has rear water ports.
Old 07-05-2017 | 05:44 PM
  #159
Maybe a silly question but why didn't you send him the complete engine to Check?
Padraig
Padraig is online now
Old 07-05-2017 | 05:58 PM
  #160
Maybe like tinkerer said. The bolt are to long but in the manifold. I started one engine in boat the other day and have the intake installed on the one I pulled. Hoping to have it in by Fri. I'd be eyeballing that intake. I had to replace my darts. They looked great but had eroded around the water ports. Probably could have used them but don't want any issues. I bought new merlin marine intakes. They have brass inserts at all water passages. I know they don't perform as well as darts but they aren't going give me any surprises
veloc410 is offline
