Milkshake on rebuilt engine >
Old 08-01-2017 | 06:50 PM
  #221
You could always unhook the water alarm sender.
dereknkathy is offline
Old 08-01-2017 | 07:26 PM
  #222
My OCD wont allow that.....lol
im gonna check all hose connections, try the 140 thermostat and see what happens.
If it still sounds alarm im going to swap the 2 senders while on the water and try again
the only thing i have to go on is
the water psi is 10# when sounding. 15# when off. Seems like it would be related to thermostat opening/closing?
temp gauge stayed at 150 the whole time till i came back to idle then dropped a little
alarm only sounds when above 2500-3000 rpms.
cabin fever is offline
Old 08-01-2017 | 07:48 PM
  #223
SB
Got a pic or diagram where all your senders are ?
SB is online now
Old 08-01-2017 | 08:00 PM
  #224
Alarm sender on the right.
Old 08-01-2017 | 08:18 PM
  #225
SB
I'm seeing adapters under each sender. Wonder if you have a grounding issue.
SB is online now
Old 08-01-2017 | 08:21 PM
  #226
I thought about that but
1 it was like that when i bought it and the problem just started
2 if it was a bad ground would it make the alarm sound? I would think the other way?
Old 08-01-2017 | 09:17 PM
  #227
Possibility that the senders being in pockets in the adapters could have them up out of actual water flow.
Old 08-02-2017 | 09:40 AM
  #228
have you actually shot the engine w/ a infra red temp gun and see if its hot?
sutphen 30 is offline
Old 08-02-2017 | 10:44 AM
  #229
Wobble's Avatar
SORE MEMBER
Make sure it's not the drive oil bottle sending the alarm, disconnect one sender at a time to be sure,
hi-water-temp, drive-oil, low-oil-pressure.
Wobble is offline
Old 08-02-2017 | 12:04 PM
  #230
fandango's Avatar
From: Solomons Island, MD, Vero Beach and Punta Gorda, FL
Sending wires crossed???
fandango is offline
