Milkshake on rebuilt engine >
Old 06-27-2017 | 08:42 AM
  #81
SB
I've never installed recirc pumps / cross overs without finger painting silicone (I use ultra black because I'm a junky ) on both sides of gasket.
No warpage is good.
SB is online now
Old 06-27-2017 | 08:47 AM
  #82
F-2 Speedy's Avatar
that flange is pretty thin...looks like 1\8 inch ............yes goop on the black stuff
F-2 Speedy is offline
Old 06-27-2017 | 08:50 AM
  #83
No warpage is good.
sb,ditch the ultra black and try the right stuff,you will be amazed at how much stronger it is.
mike tkach is offline
Old 06-27-2017 | 08:56 AM
  #84
SB
I know people love it. And thus I wouldn't advise against it. I'm just an ultra black addict and there are no organizations I can join to stop my addiction.
SB is online now
Old 06-27-2017 | 08:58 AM
  #85
F-2 Speedy's Avatar
Once you go Ultra blk, you neva go back..................lol
Old 06-27-2017 | 12:46 PM
  #86
Thanks fellas. I have ultra black. Ive heard good things about the right stuff too
cabin fever is offline
Old 06-27-2017 | 03:22 PM
  #87
You could also lay a piece of sandpaper on a table and take some of the curve out of the 2 flanges.
dereknkathy is offline
Old 06-27-2017 | 03:36 PM
  #88
I hone small flanges, exhaust risers by hand with a Norton combination stone (2"x6/8") until flat...a bit of WD40 or solvent as lubricant..brush on sealer for water joints... Looks like the goop will work...!
What was wrong with the engine anyway? That was a quick recovery!
28 V is offline
Old 06-27-2017 | 04:44 PM
  #89
Heads were not flat. Said he took .008 off which doesnt seem like much to me. He said it appeared all 8 cylinders were leaking from the get go but #5 gave up fight mostly. He swears he double checked head gasket #'s too
ill be nervous boating for awhile now. It will not be pretty if i have to pull this thing out again
in his defense he was very apologetic and im only out my time and a few odds/ends so could be worse. i just wanna do more boating and less wrenching.
Old 06-27-2017 | 04:46 PM
  #90
Sounds like builder stood behind his work which is not that common today. Good luck and let us know how you make out.
underpsi68 is offline
