Lack of oil to rockers at idle concerns
I took my time setting the preload and making sure valvetrain geometry was correct. Didn't give any attention to the lifter oil feed height compared to the lifter bore feed hole. Guess that could be the issue.
So, how much preload did you set? Maybe try a bit more or less. I can't see any manufacturer setting oil hole at the wrong height. I doubt even a big change in base circle would move hole far enough. Plus, I would think if oil hole location was off, it wouldn't change with rpm. Its not like the lifter moves farther at 2000 than 1200. And these are retrofit lifters so I doubt they are for a gen 6 block, which I bet has same oil gallery height as 4-5 blocks anyway
I just compared gen 6 roller to mk4 flat lifter. The cut-out around the waist is about an 8th inch lower on the flat mk4 lifter. I am sure people run retro lifters in 6's when the dog bones would restrict lift, but I have never heard of a retro lifter made specifically for a gen 6. You bought engine used. He might have bought lifters used. Loosen lifters up to no preload. No better? Tighten down to the max they can be set at. No better? Replace the lifters. Pull 1 and put next to flat tappet lifter to compare oil cut-away location just in case, but these lifters just ain't pumping oil. Another thought. You are looking at 1 lifter. Pull valve covers and run engine. Messy but... it might be a couple of gummed up lifters.
