AFR gauge or display? >
Old 06-07-2017 | 01:05 PM
Default AFR gauge or display?
looking for a way to read my AFR , currently all my gauges are full and I don't really want to cut a hole in my dash ! any options out there for a nice little display I can mount somewhere and is nice and visible ! thanks guys
daniel475 is offline
Old 06-08-2017 | 09:54 AM
Two options. Move one of the existing little utilized gauges to another location and put the AFR meter there.
Innovate has a hand held unit that may work for you as well. LM-2 Wideband unit.
Trash is offline
Old 06-09-2017 | 06:18 AM
Full Force's Avatar
I run the FAST system and made my own mount, easy to see and you can remove if you chose to.
Full Force is offline
Old 06-09-2017 | 06:35 AM
SB
Bluetooth okay ? Or, do you have an accesssory/cig lighter socket near you ? See pic... If so, you can boot the voltage gauge.
Also Many different surface mount or etc voltage gauges :
https://www.bing.com/images/search?q...ge&FORM=RESTAB
SB is offline
Old 06-09-2017 | 10:37 PM
Daytona Sensors makes a nice display that you could mount on your dash. It has the option of one or two readouts.
endeavour32 is offline
