Quick disconnects on power steering actuator
Your old steering hoses are SAE and the new quick release are metric. Mercruiser sells a kit with the new style lines, but its pricey. Maybe try calling a local hydraulic place and see if they have some kind of adaptor fittings you could use.
Just noticed your boat is a 1999 which has the newer style actuator, thought you had the older Saginaw steering actuator which uses sae fittings. Glad you were able to use your old hoses.
