575 fuel lift pums >
575 fuel lift pums
575 fuel lift pums
Old 06-24-2017 | 10:34 AM
Default 575 fuel lift pums
I have a pair of 2002 575's and have a fuel lift pump starting to weep oil. Has anyone replaces these, and where is the best place to order them from? Thanks
dave krehbiel is offline
Old 06-24-2017 | 11:20 AM
With it weeping oil its probably because the pump is leaking gas and is mixing with the lube. The lube should be checked every so often to make sure gas is not mixing with it. Probably need to replace the fuel pump and hope it didn't damage the seawater pump shaft seals
AllDodge is offline
Old 06-24-2017 | 11:36 AM
Yes, I just replaced both sea pumps and that's when I caught this issue. Sea pump shaft looks good so I think it just started, and I am going to replace the fuel pump asap. Any ideas on the best place to order from?
Old 06-24-2017 | 02:32 PM
889275T is the part #, they're also used on 500 and 525efi's ...they're right around $150
JaayTeee is offline
Old 06-26-2017 | 06:53 AM
dcb
Airtex PN 60932 you may have to reorient the base for the correct position for the fittings.
dcb is offline
Old 06-26-2017 | 07:52 AM
I think I found them cheaper when I replaced a few years ago. If my memory is correct, about $100 each. So do a diligent search online for the part number. I looked in my email, but didn't find my invoice.
ALL_IN! is offline
Old 06-26-2017 | 07:56 AM
Found it - I purchased from eBay. Seller was speedcustommarine24. $114 each.
They've gone up a little since then....
889275T by Mercury New fuel pump assembly | eBay
ALL_IN! is offline
Old 06-26-2017 | 08:21 AM
A tad less and free shipping
https://www.amazon.com/Mercury-Mercr.../dp/B00N9HN9MC
New Mercury Mercruiser Quicksilver Oem Part # 889275T Pump Assy-Fuel | eBay
AllDodge is offline
Old 06-27-2017 | 08:32 AM
a little fuel seepage does not mean the pump is bad,they all do it.change the lube more often and you will be fine.
mike tkach is offline
