hydraulic steering question
i currently have an imco dual ram system at the stern and cable from the helm. i have been told that a hyd helm is really better /safer on a 100mph cat and should consider it. i currently have trim control on my steering wheel and really like it. i think there is a helm setup that will alllow me to keep the steering wheel trim but in a conversation i was recently told that hyd helms do not "return to center" the way a cable systen does and that the steering wheel might not be "aligned" (ie trim switches at 10 o'clock and two o'clock position) when going straight...is this true????
thanks gary |
steering
gary unfortunatly you are correct. wheel won't always retunn to same pos. you can use side mount , it will mount at 3 or 9 o'clock (they also have a dual). they resonable and easy to install. pro trim by teleflex
| All times are GMT -5. The time now is 11:04 AM. |
