Crazy Alarm help >
Crazy Alarm help
Crazy Alarm help
Old 07-04-2017 | 04:05 PM
Thumbs up Crazy Alarm help
Hi folks. My first time asking for help. I have a 41 PC with twin (2000 502's). The port engine alarm will go off after about 20-25 min of 3000rpm run and I shut her down immediately. However, I can run for a while at idle or near idle with no issue. So far I've replaced the impeller and also the oil pressure and engine temperature are both within spec. Also, by doing a search on the interwebs I noticed that low voltage can also trigger this issue. All the batteries have plenty of voltage.
What should I look for next?
Thanks,
Tim
Blown284 is offline
Old 07-04-2017 | 04:45 PM
The drive reservoir also has a low level alarm. Did you check that?
sonicss42 is offline
Old 07-04-2017 | 04:48 PM
No, didn't check it. What drive reservoir are you speaking of and why wouldn't it be going off at low rpm?
Blown284 is offline
Old 07-05-2017 | 08:10 PM
Any other help/suggestions? Perhaps a sensor gone bad?
Blown284 is offline
Old 07-31-2017 | 07:45 PM
Figured this out too. Was the oil pressure sensor/sender wire wasn't on all the way. Glad I figured it out.
Blown284 is offline
