Starter Suggestion >
Starter Suggestion
Starter Suggestion
Old 07-13-2017 | 03:55 PM
Default Starter Suggestion
What starter is everyone using, oem or aftermart? Also, what should the minimum cranking amps be? I have modified 525sc engines with oem starters that crank slow. Thanks in advance for all replies.
Baja8808 is offline
Old 07-13-2017 | 04:35 PM
chances are your cables are corroded underneath the outer coating,peel some of it back,if it if green replace all the cables.
mike tkach is offline
Old 07-26-2017 | 01:29 PM
ATi. Brand, HD variation only.
Tractionless is offline
Old 07-27-2017 | 10:53 AM
BUP
API HD gear reduction starters. I have brand new on hand .
BUP is offline
