Engine cuts in and out
#41
35 I dont know if the grounding the blocks together could have any effect like that or . Not sure how he tested the batteries or if he replaced the batteries but when using a load tester, make sure NO other wires are connected to the batteries. And I see no reason to connect the 2 blocks together. I still think this is Battery/ ground related.
Chris
Chris
#42
So lets eliminate or confirm the battery/ground theory. Get a known ,good battery ,and put it in the boat not connected to any grounds. Connect all trim pumps , trim or tabs to this fresh hot battery. Run the boat and work the the trims and tabs and see if the motor cuts out. If motor does not cut out then it is a ground or battery problem. If it does cut out then it is not a ground/battery problem and something weird like arcing . Also pay attention to whether it does it with trim up or trim down or both. Trim up pulls more amps. These are just cheap things to try and gives us more data. You should not have the battery switch on all or both as this will confuse as to what battery or wiring might be the problem. Also you should not run with switch in all or both position as most stock alternators will not have enough juice to charge 2 large batteries . Some pics of the way the wires are connected to the perko switch and batteries may also help
Chris
Chris
#45
Chris
Chris
#46
First remove the trim pump Pos and Neg leads from whatever they are connect to on the side giving you the most trouble. . Pos may be running through the perko switch or directly to the battery. Next make sure you have the perko switch turned to battery 1 then remove all wires from battery 2 . You will have to unscrew perko switch from wall of boat to track wires to determine what is battery 2. Next hook only wires from trim pump to battery 2. So now you have a single battery set up on that side to start and run motor and an auxiliary battery to run trim pump. This is only for testing, dont try and make a day of it on the lake as the trim pumps pull a lot of juice and could run down that auxiliary battery if you run all day working the trims a bunch.
Chris
Chris
#47
Chris
Chris
#48
#49
#50
Chris
Chris
Good luck
