Broken Gimbal Ring >
Broken Gimbal Ring
Broken Gimbal Ring
Old 08-03-2017 | 09:18 AM
BUP
Alpha Gen 2 TRIM limit is pin center to pin center is 20 - 3/4 inches for alpha gen 2 next is 21 - 3/4 for alpha gen 1 and next is bravo & Blackhawk is 21- 3./4. that trim limit as that has nothing to do with full tilt up position. Tilt is all the way up in which has nothing to do with trim limit . When the rams fully extend thats full tilt up for trailing. Again trim limit has nothing to do with that.
trim limit is for limiting the trim not past a certain point WHEN RUNNING ON THE WATER - why limit - one is limiting stress on the u joints and 2nd not to over trim the drive height so the water inlets suck air instead of water. Also limiting trim position for handling purposes as well. That's what trim limit is for and that's why the unit is called tilt and trim.
BUP is offline
Old 08-03-2017 | 09:29 AM
BUP
Found this -- the specs for trim limit listed is more so at the bottom of the link below when opened. For whom ever to follow the trim limit and its specs . I already posted the trim limit specs but they are listed with pics in the link in which is a better understanding.
https://www.perfprotech.com/store/ap...rim-sender.pdf
BUP is offline
