Carb tunning question >
Old 08-25-2017 | 11:02 AM
Originally Posted by cabin fever
Thanks. Im gonna send the distributor back to msd over the winter to get rebuilt so ill look at locking it oit when i get it back
for now ill make it work till winter.
Before you send the distributor back try this its easy and it will take less than 30 minutes I have a feeling you'll improve if not get way closer were you need to be. Remove the cap and rotor remove the two springs and replace with the springs with the light blue MSD springs and underneath the rotor plate there's a 3/8 nut with a stainless washer that holds a bushing in place remove the bushing and replace it with the MSD black bushing . Start the engine and set the base timing at 20 degrees and check the total timing to not exceed 35 degrees by 3500 rpm. Please let us know how it works for you and also if you don't have the springs and the bushing call me with your address and I'll send it to you no charge. Sincerely Laz
MESABALANCING is offline
Old 08-26-2017 | 09:03 AM
I would take the caps and rotors off, and take a good look at the advance mechanisms. They are notorious for rusting, sticking, binding, broken springs, and so on.
MILD THUNDER is offline
Old 08-28-2017 | 11:36 AM
I actually had the distributor out this summer and cleaned it up while the motor was being rebuilt. It looked ok to me but i dont remember what springs/bushing were in it
Saturday the boat actually idled pretty good in and out of gear but the idle was a little higher the. I want was right under 1000 in neutral. I think it needs to ne around 800 for the bravo?
cabin fever is offline
