-   -   Difference between pulling boat with transmission.and Stern Powr (https://www.offshoreonly.com/forums/general-q/349704-difference-between-pulling-boat-transmission-stern-powr.html)
Warship2k15 09-10-2017 12:56 PM
Ok I've decided to pull my engine and transmission.
I've pulled Alphas and Bravos but never one with the transmission attached.
I know with the others you pull the drive first.
To add another thing this boat has a Stern Powr drive.
So what's the proper way to go about this??
dereknkathy 09-10-2017 01:19 PM
You can usually pull engine forward enough to free spline from the driveshaft, but putting it back the same way is a pain. Stern power is no worse to pull than any other drive. You weren't changing the cam with engine in place anyway.
Warship2k15 09-10-2017 01:41 PM
I could but it doesnt make sense to do it that way.
Do you know if stern Powr uses the same alignment tool as merc or volvo?
