Motor problems >
Motor problems
Motor problems
Old 10-31-2017 | 08:44 AM
Originally Posted by Tractionless
Trey did you check fuel pressure as indicated above by Veloc?
I checked the fuel pressure on the fuel rail and I am getting about 35psi with it running.
Trey27fountain is offline
Old 10-31-2017 | 03:26 PM
I got 48 lbs on both of the engines after I replaced the regulator on port side. The port wngine would not hold pressure when it was turned off. When I pulled the return line off the fuel regulator I saw a lot of fuel getting past the regulator when the key was turned on. That fuel pressure should hold when key is off. Turn key on for a few second then off pressure should not drop. If you wait a minute then check pressure it should still be there
veloc410 is offline
Old 10-31-2017 | 03:43 PM
I know your fuel rail is different but same regulator. Its actually just a pressure relief valve. There is a brass tube in the end with O rings on it, don't loose it. The new one does not come with it and use grease on all o rings when you reassemble. You can see the cap for the shrader valve and the fuel rail. My pressure regulator is underneath the fuel rail.
veloc410 is offline
Old 10-31-2017 | 03:53 PM
I will check fuel pressure like you say and go from there, thank you for your help I really appreciate it.
Old 10-31-2017 | 03:57 PM
No problem. That was on my last boat that someone I know bought from me. He had this issue in August and I helped him trouble shoot it
veloc410 is offline
Old 11-05-2017 | 10:17 AM
I just hooked up a fuel pressure guage and when the key is on the pressure goes up and when you turn the key off the pressure drops to 0.
Old 11-07-2017 | 07:34 AM
Pull the return line off the pressure regulator , have someone turn key on again and see if fuel squirts out of regulator. Start looking for a new one. They are hard to find. You will most likely find it on line. I found the one I needed on ebay but like i said if you can' find it, look up the regulator by the raised letters on the casting. You might find it at an auto store. When I looked it up Honda civic came up. It's a Japanese part.
veloc410 is offline
Old 11-07-2017 | 07:46 AM
http://www.michiganmotorz.com/mercruiser-fuel-pressure-regulator-p-4612.html?gclid=CjwKCAiA0IXQBRA2EiwAMODilzqMJ3xmpK 4y-dKP-XaFf7gzAQ1ZTqgnvv4cmRFDALOuIwsMKNNlMxoCJkcQAvD_BwE
veloc410 is offline
Old 11-07-2017 | 07:54 AM
Any way I just punched in NR1 fuel pressure for mercruiser. Michigan motors came up .118 bucks. I think we found ours for 100
veloc410 is offline
Old 11-07-2017 | 07:58 AM
861126a1
veloc410 is offline
