Battery System >
Battery System
Battery System
Old 10-19-2017 | 06:32 PM
http://
Bt Doctur is offline
Old 10-19-2017 | 06:40 PM
You are correct, with both switches on #1, both motors are drawing from one of my banks (2 blue tops), and yes both motors have alternators that are pumping 13.9 volts on the system. And I guess if I'm on #1 position on both switches being that my amp is connected to #1 also I have it running too.
How would I separate the house system(amps and fridge)? Also what about charging, should the alternators really only charge the starter batteries? And lastly, are my blue tops ok for motors?
Hogheadsena is offline
I have 3 batteries.
1 for each engine and one as a house battery to run stereo. The stereo battery is a deep cycle , the others are starting commercial batteries.
The "house battery" (stereo) is on a charging relay/isolator to prevent any issues with charging, or starting issues. I can run the house battery down and still able to start
I got this recipe here and it`s been working perfectly
https://www.bluesea.com/products/761...12_24V_DC_120A
p.s. I find Optimas to be complete garbage.
and
ICDEDPPL is offline
Old 10-19-2017 | 06:45 PM
I have twin engine 496HO and yes each motor has an alternator. What does ":Optima Bats are carp IMO" mean. Sorry, I am new to power boating and trying to learn all the terms.
Old 10-19-2017 | 06:47 PM
" optima batteries are crap ...In my oipinion "
Runs 3 amps , no issues
ICDEDPPL is offline
Old 10-19-2017 | 06:55 PM
I have 2 large amps, one of which draws about 30amps and other will draw less that 10. What do you suggest I do with wiring system? I have 2 switches that have busswork connecting both post #1's together and both #2 post together. The on-board charging system is a 10amp charger that is designed to charge 2 batteries at the same time and this is wired up to each post (one on both post#1 and other on both post#2)
Old 10-19-2017 | 07:34 PM
SB
Carp was a mistype. Crap was what he tried to type.
IMO = In my opinion.
SB is offline
Old 10-20-2017 | 01:20 PM
I would isolate your house loads from your engine/drive loads and install a Blue Seas ACR.
Starting battery for engine. Deep cycle battery for house load (your amps, fridge, etc).
The link that ICDEDPPL posted is what your looking for.
More specifically, if you actually need 2 house batteries, I would purchase 2 of these....
https://www.bluesea.com/products/765...ery_Kit_-_120A
They are very simple to install and prevent any drain on your engine starting batteries from house loads.
ALL_IN! is offline
Old 10-20-2017 | 01:35 PM
I made a long post, but system crashed and didn't go through - I'll cut to the chase. Buy 2 of these, isolate your house load from your engine/drive load. All house loads should go to a house battery.
ALL_IN! is offline
Old 10-21-2017 | 02:51 PM
This diagram from their page might help , I've been running a combiner for years with no issues although man they have evolved price wise .https://www.bluesea.com/products/761...12_24V_DC_120A
midwest272 is offline
