Originally Posted by Interceptor
(Post 4591029)
fog engine
pull block drain plugs and poke openings to insure not caked with sand pull manifold drain plugs pull oil cooler drain plugs pull lower hoses off engine pull hoses off raw water pump pull hull drain plug drives neutral remove batteries raise front of trailer cover and walk away, has worked for 18 years in northern Michigan cold indoor storage. |
Drain all water from engine block , manifolds , coolers etc etc ... We put sterndrive into 110 gallon of -50 . Start Engine , spray fogging oil in engine while running . When antifreeze flows out exhaust , we quit . I've disassembled literally 100's of engines that have been fogged . If they werent fogged , they started flash rust on the cylinder walls in a matter of hours. We would fog all race engines after the race. If the tuner forgot , or wasnt able to , the cylinder walls would stain up , on the truck ride home.
Originally Posted by dunnitagain
(Post 4591421)
| All times are GMT -5. The time now is 08:12 AM. |
