mercury 540 565 camshaft specs >
Old 11-01-2017 | 10:12 PM
Originally Posted by MILD THUNDER
Same cam the 525EFI uses. They use it in the 525, 520, 540, and 565 engines.
are you positive the 565 is only the 525 cam. I have a buddy with two 565s in a small cat and they sound pretty nasty compare to a 525.
fastenuff2 is offline
Old 11-01-2017 | 11:23 PM
Exact same Merc part number for all of them Genuine Mercury & Mercruiser parts. Racing & Hi Perf Sterndrive Engines
Griff is offline
Old 11-02-2017 | 05:08 AM
SB
Originally Posted by Griff
You are correct.
I just double checked by looking up each engine individually - 525EFI, 520, 540, and 565. I did this at Genuine Mercury & Mercruiser parts. Racing & Hi Perf Sterndrive Engines
They all have Mercruiser #400-8M0043065
SB is offline
Old 11-02-2017 | 05:55 AM
Sonic30ss's Avatar
IMO it's a great all around cam, sounds nasty but has great dock manners, making 640 reliable hp with it. Displacement will move peak power around.
Sonic30ss is offline
Old 11-02-2017 | 06:37 AM
SB
After all that I forgot to list the specs:
525 EFI
298º/306º @ .004"
236º/244º @.050"
.610"/.632" Lift Valve
114º LSA
SB is offline
Old 11-05-2017 | 10:02 PM
can you post some info on your engines like cu in,compression ratio and heads?
mike tkach is offline
Old 11-06-2017 | 05:23 PM
Sonic30ss's Avatar
548"
dart 308 head
Callis cranks
eagle rods
je pistons
9.6:1
https://www.youtube.com/watch?v=u5JcAOsrT_M&feature=share
