Supercharged 502 EFI Question >
Old 09-19-2003 | 01:58 PM
dadinator
I had this happen on my 454 mag/efi's with a Whipple System. Engines had about 90 hours before blowers and about 150 with blowers. Compression check before blower installation was good. Also was getting a lot of gas in the oil. Finally lost a piston or rings on Labor Day. Going to new 502 blocks and blower pistons per the recommendation of an engine builder. What is it about "blower pistons" that make them less prone to this? Different ring groove shape, different ring geometry, what?
Still love the blowers. Going to stick with them.
Old 09-19-2003 | 08:05 PM
paradigm shift's Avatar
If you are getting gas in your oil you need to find out why. Overly rich conditions will wash the cylinders walls down and cause ring failure and excessive wear in your motor. Detonation is the worst for breaking rings and top ring lands. Blower pistons are forged which I believe your mag motor should of had. Forged pistons are stronger.
paradigm shift is offline
GSS0816
5
07-25-2007 02:11 PM
GSS0816
10
07-04-2007 02:11 PM
thedonz
2
06-18-2004 01:19 PM
BryanTuvell
4
02-26-2003 02:17 PM
wwbobb
3
09-17-2002 09:26 AM
