head gasket selection >
Old 11-06-2017 | 02:30 PM
BBYSTWY's Avatar
good to know griff thanks!! I think if I can get away with the cheaper route ill probably do that as im looking at buying a complete shortblock now possibly so no reason to tear it apart to have the head cleaned up just for the purpose of running a gasket that I probably don't need
Stewart
BBYSTWY is offline
Old 11-06-2017 | 04:03 PM
SB
IMHO: Felpro HG (more forgiving and you have mild engines) and ARP Bolts. Studs harder to seal in 454 blocks, studs can interfere with other things, plus the bolts will handle pantloads of HP. Pantloads = a schitton.
SB is offline
Old 11-06-2017 | 04:04 PM
BBYSTWY's Avatar
kinda what I was thinking thanks!!
Stewart
BBYSTWY is offline
Old 11-06-2017 | 07:56 PM
Originally Posted by TorchLK
I'm sure a stock style head gasket will work just fine but I would highly recommend stepping it up to an MLS. Especially since you are re-doing everything you can have the heads and block finished to the correct surface finish for an MLS.
I cant think of any drawbacks to an MLS if done properly. I cant actually name a modern engine that doesn't have an MLS gasket.
Also, what is your reasoning for recommending head bolts over studs?
have you ever had the pleasure of removing an aluminum head that has been on a cast iron block with steel head studs?after about 5 years when the heads need to come off it is dam near not posable because of the corrosion from the dissimilar metals.the head stud is bigger through the middle and promotes the corrosion.
mike tkach is offline
Old 11-06-2017 | 08:23 PM
steel heads... use a permatorque head gasket and the appropriate ARP bolts... IMPO
adk61 is offline
Old 11-07-2017 | 06:12 AM
BBYSTWY's Avatar
thanks guys!!
BBYSTWY is offline
Old 11-07-2017 | 06:26 AM
BBYSTWY's Avatar
how do I determine what thickness I need??
Stewart
BBYSTWY is offline
Old 11-07-2017 | 09:50 PM
Stewart
.039 is pretty normal. Going up or down will change compression and quench slightly.
Griff is offline
Old 11-07-2017 | 10:25 PM
7-8lbs boost? Dart Heads? Chiller? Upgraded cam? you're gonna be spinning the bearings out of the 177 trying to get 8lbs of boost.
better heads, better cam, drop boost and gain power. Chiller is a bit of a restriction, and blower needs to be spin faster to overcome that. That tiny blower is gonna be working overtime for minimum wage.
imo, you wanna run 8lbs on that combo, get a 8-71.
As for head gasket thickness , as long as your Pistons aren't above the deck, a .040 gasket should be fine.
MILD THUNDER is offline
Old 11-08-2017 | 05:44 AM
He did say that he is upgrading the blower to 575 blower, still small at 250/256 but should be OK for a 454.
JRider is offline
