manually turn crankshaft >
Old 11-29-2017 | 11:08 AM
Default manually turn crankshaft
with engine out and plugs and belts removed how much effort should it take to rotate a 454 crankshaft clockwise ? Not a new or rebuilt engine.
Interceptor is offline
Old 11-29-2017 | 11:14 AM
F-2 Speedy's Avatar
should roll over fairly easy with a 1/2 inch breaker bar and socket..............
F-2 Speedy is offline
Old 11-29-2017 | 07:41 PM
Your still compressing a bunch of valve springs also
class6 is offline
Old 11-30-2017 | 08:57 AM
I rotate my 525EFI with a 3/4" socket on a 3/4" drive ratchet. Piece of cake.
HyFive578 is offline
Old 11-30-2017 | 09:17 AM
Thanks, I got it turning, didn't want to break off the bolt head.
Old 11-30-2017 | 09:44 AM
Knot 4 Me's Avatar
I can tell you that you will never get one to turn over by hand with the rod sticking in the side of the cylinder. Been there, done that!
Knot 4 Me is offline
Old 11-30-2017 | 06:58 PM
No doubt. Once you hear it going with a stocker just leave it pinned til chit happens. When you come to a abrupt stop and look under engine and see oil and antifreeze/water - not a good sign but on the flip side time for new build and more power. Lol... usually results in a nasty hang over also.
I had one I could litterally stick my entire hand through the oil pan.
getrdunn is offline
