How to Lower Compression? >
Old 12-05-2017 | 08:10 PM
Originally Posted by PORT
I'll reach out to builder tomorrow and see if he keeps records.
Engine is in a 22' Talon and does 105-108 on GPS every time, just wanted to put her in the upper teens.
Outboards are so much EASIER & CHEAPER (LOL)
Be careful.... I think if you get with engine builder and result in some head and intake work and possible timing etc you'll be able to achieve close to your goals. Maybe cam change but your cam seems like it would be within reason if your wanting to stay at or close to 5,500. Cam may be just fine with some head work. You have a nice build there. I'm jealous. Lot of good parts. I just think there's power left on the table. If you can post a cam card it would be interesting to see your timing events.
getrdunn is offline
Old 12-05-2017 | 08:45 PM
Tinkerer's Avatar
MiId Thunder - the fact that he isn't putting out much HP with that many cubes tells me he either has real bad heads or a very mild cam.
So with the proper cam I figured he should get it into the HP range he wanted without spending all of the $ on blowers.
I would cam it for at least 6000 RPM because cats like RPM.
Tinkerer is offline
Old 12-05-2017 | 09:36 PM
He's got a nice conservative build that would likely run many trouble free hours. Tinkerer like you mentioned cam would definately help like something in the 260/270-714-714. Existing cam would be fine with the whipple I think anyway. Just depends on what direction he goes. I think once he finds out what he has for head gasket, stock chambers or not, pistons at tdc etc then he can at least see if it's remotely possible to get near 9.0:1. I have a feeling it's gonna be difficult if it's actually 10.5 currently. That's possible an oversite given flat tops and if stock 121 chambers so might get lucky. In my opinion I'd run it hard and spray it til its ready for rebuild then get comp down. Meanwhile NOS it. That alone will probably expedite his future whipple. Lol.
getrdunn is offline
Old 12-05-2017 | 11:06 PM
Originally Posted by MILD THUNDER
With some chamber porting, and thicker head gaskets , he could be down in the 8.9:1 range. I would have no issues putting a blower on a 9:1 engine, as I have and had no issues doing so.
Compression Ratio Calculator Tools Diamond Racing Pistons
after a little thought i think a 3.3 a little on the small side for an engine his size so 9 : 1 would work well in this case,jmo.if he had a larger supercharger in my opinion he would make more power and the engine would live longer with less compression and more boost.if he was going pro charger i would say raise the compression to close to 10:1.
mike tkach is offline
Old 12-05-2017 | 11:14 PM
i see two problems spraying it,one he will need a barge to haul the nitrous that can,t be had anyway since the plant in florida blew up and two,if the nitrous tune up get,s a little lean it will be over before he can back off the sticks.
Old 01-07-2018 | 02:07 PM
Smile
I see your mother had obviously dropped you on the coconut much harder than her sister did to me. Leave it be, it's so much more relaxing drinking and listening to the radio than working on things that will break more often and they do break
homan is offline
