Weldon Fuel pump Question >
Old 12-13-2017 | 04:54 PM
Originally Posted by 47EXCALIBUR
You left out the brand dummy WELDON
well this thread is about weldon pumps.so I wasn't wrong this time.
sutphen 30 is offline
Old 12-13-2017 | 07:39 PM
phughes69's Avatar
Back in the day (20 years ago) we use to run Weldon on all the big HP cars that we would build. Weldon pumps are rated for aircraft use, that might tell you something. You cant have a fuel pump fail in the sky. I run one of their regulators in the street car. Its dead nuts accurate. Had to replace a diaphragm in the regulator because the alcohol in the fuel cracked the rubber.
phughes69 is offline
Old 12-13-2017 | 10:02 PM
I run the Weldon 1100-a pumps on just about everything. Have nothing bad to say about them.
snapmorgan is offline
Old 12-14-2017 | 04:23 PM
Thanks for all the imput.
Single cat is offline
Old 12-15-2017 | 12:01 PM
BUP
Originally Posted by GPM
Been running Weldon pumps in boats since 1997, 2015, 2025, 2345, with Weldon regulators, no issues unless filters get clogged.
Just asking " no issues unless filters get clogged " what filters and if any filters that are getting clogged to restrict fuel flow -- one has possible some major issues with and how any filters become clogged.
BUP is offline
Old 12-15-2017 | 12:32 PM
14 apache's Avatar
Think what he is saying it will burn the motor up on the pump when the filter gets clogged. I have bin there also. Kinsler makes a mega monster filter with a built in check valve huge compared to the smaller filters.
14 apache is offline
Old 12-15-2017 | 01:23 PM
BUP
I understand that no matter of the fuel pump. I thought he was having problems with his fuel filters getting clogged and more than once. But maybe he was making general statements about getting filter clogged. But again that holds true for any fuel pump.
BUP is offline
Old 12-15-2017 | 03:50 PM
GPM
They are fantastic pumps, run forever with plenty of volume and pressure, the only ones I found to feed 8 to 1500 hp. We had 1 burn up because of water going through the filter, it swelled up the cellulose element and caused enough restriction to fry the motor. This was NOT a bad pump just an unfortunate situation. The filters were Weldon pre and after filters. They recommended using the Ramco filter / separator, no problem since. I'm sure any pump would have failed under those circumstances.
GPM is offline
Old 12-15-2017 | 11:53 PM
BUP
I hear you and totally understand - Just saying on my part, I sell the Weldon 1100 pump more than any other version for non stock apps and its the FST filters since they bought out Ramco about 4 years ago. I sell that as well. About 35 to 40 of those filters per year. Matter of fact, I just cut open a FST filter yesterday from a customers boat using the weldon 1100 pump and the past week was talking to the owner of weldon -- Jim C in person...
I totally understand and no matter of anyones engines and fuel pump installed - if one is clogging fuel filters - one has contamination issues hugely of their fuel system. I would address that issue ASAP. Not only will it hurt fuel pumps but cause lean conditions for the engine(s) in short order.
Merc Racing engines use this same FST filter as well. OEM stock install from Merc racing.
Also thanks for the reply and your time posting.
BUP is offline
