-   -   Quick question on motor refresh (https://www.offshoreonly.com/forums/general-q/351372-quick-question-motor-refresh.html)
BeaverJ 12-18-2017 10:06 AM
Guys I'm looking at a 99 boat w/ 500efi's w/ 300hrs. Seems like everything I read says the motors need refreshing about that time. Can anyone give a ball park figure as to what that normally runs $$? The motors would have to be pulled obviously. And also at what point is it time to redo the bellows and what does that normally run$$? Again I just need ballpark figures, I'm in Arkansas near LOTO etc. Thanks
dcb 12-18-2017 10:31 AM
Top ends at 300 hours - bellows should have already been done. Prices will vary depending on what is needed. Did top ends on one 575sci - new head gaskets, bolts all new valves springs retainers etc with machine shop time for about 3000.00. I supplied the labor. Had a very reputable marine tech - Dave at MDG , perform the assembly and parts purchase.
Griff 12-18-2017 12:52 PM
Should need top ends only refreshed. Prob 3-4k per engine depending on what parts are needed.
Pismo10 12-19-2017 09:00 AM
Can do top in boat.
F-2 Speedy 12-19-2017 09:16 AM
to the OP, are you a mechanic, are you getting the hours from a scanner ?
BeaverJ 12-19-2017 12:30 PM
No sir. The seller listed the motors at 300 hrs.
Knot 4 Me 12-19-2017 12:49 PM
Verify hours with a scanner. I'd pull engines to do the top ends.
Griff 12-19-2017 01:02 PM
I've done top ends on 2 different single engine boats. One in boat and one with taking the engine out.
I would never do one in the boat again and would never attempt it with twins.
F-2 Speedy 12-19-2017 02:30 PM
If you need some help let me know, what make is the boat...........where are you in AR kan sa
Edit: dont buy anything without scanning the pcm's, they tell all
BeaverJ 12-19-2017 08:04 PM
Thank You very much for that offer!! The boat is a 99 Fountain 32 Fever, and I'm in Rogers/Bentonville
