-   -   Scorpion 4014 roller rockers on 496. (https://www.offshoreonly.com/forums/general-q/351378-scorpion-4014-roller-rockers-496-a.html)
jens henrik 12-18-2017 02:40 PM
Hi Guys.
Hope you can help me out here.
Do any of you guys know if the 4014 Scorpion roller rockers with the arp 135-7201 studs will fit under the stock valvecovers on my 496 MAG HO.
Regards.
Jens henrik.
class6 12-18-2017 03:13 PM
Are you doing springs also
jens henrik 12-18-2017 03:18 PM
No, just the rockers if they will fit under the stock valvecovers.
class6 12-18-2017 06:16 PM
I have a few HOs, Whats your reason for the rockers?
and yes they will fit
jens henrik 12-19-2017 12:56 AM
I have converted my 496 mag into a 496 mag Ho and installed a set af Stainless marine manifolds aswell. I have a set of 4014 Scorpion roller rockers i will install, just to beef up my valve train, but only If they will fit under my standard valve covers. Will they be plug and play??
Ryan00TJ 12-19-2017 06:02 AM
I planned to do this exact setup a year or so back. Called Scorpion and asked the same question. They replied it "SHOULD" fit under stock valve covers. I did not want to be the test dummy or have to cut down the polylocks. I purchased a set of Raylar's rockers and AFN nuts proven to fit under stock covers. Must further add that valvetrain geometry is spot on with their setup on the stock guideplates and studs.
https://i.imgur.com/XpHjDGF.jpg
jens henrik 12-19-2017 07:45 AM
Thanks Ryan.
I would like to know for sure, cause If they dont fit i will skip the projekt.
jens henrik 12-20-2017 07:17 AM
Anyone else done this??
Ryan00TJ 12-20-2017 06:14 PM
Originally Posted by jens henrik (Post 4600174)
Thanks Ryan.
No problem. I was in your same situation. class6 stated in an earlier post that they will fit. Might want to contact him for sure. I could never get a 100% for sure answer.
dereknkathy 12-21-2017 06:11 AM
Why does everybody use polylocks? The stock style jam nuts are just as strong and stay put. Polylocks are for constant lash adjustment with solids. And the poly's are what stick up so high.
