-   -   Cat hull vs V Hull (https://www.offshoreonly.com/forums/general-q/351642-cat-hull-vs-v-hull.html)
Single cat 01-07-2018 11:51 AM
Cat hull vs V Hull
From my perspective the engine combinationd and engine setups on bigger V bottom boats is alot different then in a cat hull. Is the big reason because they run so much deeper in the water and are a lot heavier and harder to plane ?
getrdunn 01-07-2018 03:08 PM
Definately two different breeds but a lot can depend on the V bottoms efficiency weight, step, pad, drive height etc. But would set up differently. Nice thing about V bottom builds, they'll work well in in both assuming their set up right to begin with. I've never owned cat but just voicing my opinion. In a nutshell I wouldn't set up drastically different.
Single cat 01-07-2018 03:54 PM
I here ya. The only reason I ask the question I have never owned a v bottom but have had 5 cats.
jeff32 01-07-2018 04:11 PM
The only reason for me to read your tread is, i owned more than 5 V's but no cat!!!
lol:)
getrdunn 01-07-2018 06:51 PM
lol:)
Same here. Some baller will chime in soon. Lol... It would be nice to have one of each.
Single cat 01-07-2018 06:57 PM
(: lol
turbo2256b 01-07-2018 07:22 PM
I have 8 cats that dont want to go out side cuz its too cold about to drive me nuts.
Single cat 01-07-2018 07:33 PM
Do v hull boats not load the engine a lot harder down low and through the RPM range ?
getrdunn 01-07-2018 08:12 PM
I would think a cat would also at least until it got up to speed while getting the lift from packing the air under it. But until that point not real sure. Assuming both boats are some length what one actually has more hull in the water. Not sure on drag at lower speeds. I've always heard once you go cat you don't go back. Every now and then I see some affordable 31 American Offshores out there that look tempting. Just not sure how Lake Michigan would deal with it on long runs. Great Lakes can be very unpredictable.
hogie roll 01-07-2018 09:47 PM
lots of variables. Weight, deadrise, hull width and chines. And CG relative to the back of the boat.
Id guess that in general you are correct since cats have less dead rise and they probably push the tunnel ceiling into the water when plaining. Which would create a lot of lift.
