Seized Trim tabs >
Seized Trim tabs
Seized Trim tabs
Old 01-10-2018 | 10:03 AM
Default Seized Trim tabs
I purchased a used set of 280's and one of them is seized up. I tried lubing it and working it back and forth but its still very tight. Any ideas?
gttdnbman is offline
Old 01-10-2018 | 12:24 PM
Is it seized up at the hinge or the cylinder? I'm assuming you removed hyd hoses.
getrdunn is offline
Old 01-11-2018 | 07:52 AM
Wally's Avatar
Were doomed!
i had one like that....took a sawzall and cut the shaft into multiple parts and they came out easier....one section was stuck solid so i had to drill it out...the shaft is 1/2" stainless OD rod thats threaded on the ends...i went and just made a new one instead of buying one from merc.
-Wally
Wally is offline
Old 01-11-2018 | 10:05 AM
Thats a great idea! Yes the cylinder is removed, I used some C clamps and clamped it to a top and can get it to move a little...
