Raw Water / Fuel Lift Pump Toast?
Does that disk strike the fuel pump arm riding on the cam lobe? I didn't check to see if a disk was present, intact etc. Will do this weekend when I go back with the new fuel pump. Hope to hell it isn't the raw water pump.
Keith
The pump arm sits against the bearing (I have been calling it a disk). The bearing is round, and the cam lobe is on the inside. As the pulley turns it moves in/out against the bearing pushing the arm. The bearing is just a piece of metal which has lube between it and the cam inside.
I don't see the fuel pump arm keeping the pump from turning, even if the bearing was froze to the cam lobe. I'm thinking there is something wrong with the pump bearings and it was in a bind somehow.
Thanks all!
Keith
Looks like the RWP is fine, the eccentric doesn't feel any different than the good RWP one does when spinning by and and thumb pressing hard against it. I installed the new fuel pump and the entire assembly spins freely. I chalk it up the the mechanical fuel pump on the brink of failure. Great thing it caught it on the trailer rather than potentially costing me an engine!
I hope the new fuel pump also fixes my 1k rpm idle surge issue, but it's probably not that simple. Been chasing it over a year now.
Keith
Keith
