Oval or round port heads on 454 330
Wonder if the big heavy cruisers that are hauling azz at 23 knots always seem to have 454/330's with the peanut port heads. Need to have a race off with two of the same ol 32 carvers with 330's and 365's both old school carbed. Just saying it would be kinda funny/interesting to see the results.
"781" That is correct-a-mundo! That's what I get for not checking before I type! Thanks!
We opened up the ports a little on the my 049's and smoothed up some of the angles and around the valve guide, then matched the intake. 107% VE on dyno! Not sure what the high dollar heads are doing, but in below 6k rpm action, that's pretty good!
I took square ports OFF my engines. I had contacted Lingerfelter (back before he was too famous to talk to) and my motors were built on his specs for a low-end torque monster motor. His theory (at the time, anyway) was factory square ports gave up to much on low end and didn't get it back until above 6500 rpm. Since boat are basically running uphill all the time, the torque curve needed to be flatter, which would work better across the board in boats. I'm sure head technology has come leaps and bounds since then, but 107% VE? Not bad.
I can understand that. That was one of the reasons they went to the peanut port heads. In the family truckster they never saw the numbers that would even make the big ovals efficient.
Its all in what you build. If building a torque monster for a cabin cruiser the PP heads are for you. 500+hp N/A motor for a flat bottom....
Damn. Guess I'm not as old as I thought I was. All the gen 4 merc. base 454s I have torn down were flat top peanut port motors with a steel timing chain set and a non emissions cam. 781s with bigger intake valves were the preferred set up on the gale banks turbo jobs I believe
I've heard of guys using the peanut port heads with sc 177's. I'm mean the actual peanut port (small). I'd think it would build to much heat but with low boost I guess.... What ever works for ones budget.
