Gil or emi exhuast >
Gil or emi exhuast
Gil or emi exhuast
Old 02-07-2018 | 10:41 PM
Default Gil or emi exhuast
i have gill set up and emi set ,,,which ones would yall use to run ,,,stroked 496,,550 hp
jdf4068 is offline
Old 02-08-2018 | 01:10 AM
I would run the ones that look to be in the best condition, assuming they both have the long risers. You won't see any difference in power.
Griff is offline
Old 02-08-2018 | 01:30 AM
Thanks ,,emi r brand new ,,, and do have the 3 taller and longer riser ..plus emi is abt 15 # lighter ,,
jdf4068 is offline
Old 02-08-2018 | 09:33 AM
DiamondPerformance's Avatar
Offshoreonly Advertiser
If the EMI riser is 3" taller, they won't line up with your exhaust holes in the transom, if you have standard risers now.
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline
Old 02-08-2018 | 03:36 PM
. Thanks for the heads up..also have standard riser too...the taller ones already have a port for Afr sensor plus i have some angle adapters ..helps when u worked for an oilfield company that have welders on hand to make crap for u out of left over stuff..lol
jdf4068 is offline
Old 02-08-2018 | 04:24 PM
If your running a high lift cam you can redrill the holes, if no high lift cam then standard rise should work
AllDodge is offline
Old 02-08-2018 | 08:54 PM
Is just a comp cam 547/547 lift ......
jdf4068 is offline
