Looking for a Blackhawk Drive >
Old 10-24-2002 | 02:52 PM
Dredgeking's Avatar
HMMMM. I WONDER HOW I WOULD WORK ON MY 29' FOUNTAIN. MIGHT BE SCARY. SCARY IS GOOD, RIGHT?
Dredgeking is offline
Old 10-24-2002 | 03:41 PM
timucin's Avatar
thnx for input :cord
timucin is offline
Old 10-24-2002 | 04:17 PM
throttleup's Avatar
Default props
Props can be difficult to come by I have 27's and 31' if that is of any help. Give me a call. Throttle Up Propellers 877-842-6855
When you feel the need for speed...Throttle Up!
throttleup is offline
Old 10-24-2002 | 09:13 PM
Default Blackhawk drive
Call Gary Mizenberg @ Performance Marine in Oshkosh. 920/236-4220
deboatmon is offline
Old 10-25-2002 | 11:38 AM
jollyroger's Avatar
BlackHawks are a great drive. The down side was how they were used by some mfg's. Donzi, as much as I love them, really hurt the BlackHawk program. They did not mount them high enough on the 22 Classic, and they added way too much rocker to the bottom of the hull. This resulted in an ill handling, porpoise prone boat. At any other speed other than WOT, you had to drag some serious tab to keep from porpoising. Other mfg'g mounted them too high, and they had no bite. Scarab did a pretty good job with the P-29 & the BlackHawk drives. The internals are all Bravo, so, with the exception of the gearcase, everything internal is replaceable/upgradeable. I think IMCO used to even make a short version of thier torsional vertical shaft for the 'Hawk.
You need to use the BlackHawk on a relatively small lightweight hull. A little rocker in the back would help out too.
I currently have a 97 Donzi 22 Classic 454MAG 385hp (Stock hull, no rocker) that I just hung a BlackHawk on, with no increase in X-dim. I got a 4 mph increase. I went from 68-69 to 72-73. Over the winter I plan to raise the engine 3" and use an IMCO extension box. I'll post the perf data as soon as I have it in the spring.
Woodsy
jollyroger is offline
cobra marty
16
09-29-2016 10:01 AM
omerta one
Wanted
0
05-02-2008 08:57 PM
legendlc
Drives and Lower Units
13
05-21-2007 07:34 PM
375stinger
31
06-02-2006 09:39 AM
obnoxus
Baja
3
02-10-2003 07:27 AM
