ignition coil >
ignition coil
ignition coil
Old 02-27-2018 | 07:55 AM
Default ignition coil
Hi all, I'm thinking about changing my stock mercury marine coil, not sure of the volts to an 45,000 volt aftermarket performance one 0.6 ohm low resistance by pertronix on a late 90,s 454 bravo engine , could this hurt ? guess i'm looking for better fuel burn /performance any thoughts thanks.
steve00 is offline
Old 02-27-2018 | 08:09 AM
Is the engine still at the factory delivered 8.8:1 compression ratio? Did you add a super charger?
Jeff
hallj is offline
Old 02-27-2018 | 08:14 AM
Jeff
pretty much stock set up
steve00 is offline
Old 02-27-2018 | 01:05 PM
You will gain nothing and lose reliability. Tried going to an MSD coil on my 525SC. No change in anything and it didn't last 2 years before it died.
Griff is offline
