-   -   What Procharger Should I Use? (https://www.offshoreonly.com/forums/general-q/352606-what-procharger-should-i-use.html)
tmmii 03-12-2018 05:43 PM
Originally Posted by turbos230 (Post 4615359)
Ok good but everyone needs to be calm it sounds like anger is starting to grow and I dont know why, this is supose to be fun
I think before you spend 20k or 30k it is good to ask questions and understand why the things are how they are.
The question is why not that big double pulley chrome beauty supercharger.I am attracted to it. I am going to go with whipple but I am trying to decide which one
To me it either the 8.3 or the double pulley quad rotor
FOAC intercooler with the 8.3 or quad rotor with FOAC :eek:
20-30k? Thought you had a twin engine boat and wanted to convert to efi Whipples and their moacs?
mcollinstn 03-12-2018 07:03 PM
I looked thru the newspapers, but I didn't see anything about THAT Black Friday sale..
MC
tmmii 03-12-2018 07:20 PM
MC
must have been brown Thursday starting at 6pm?
MILD THUNDER 03-12-2018 10:10 PM
https://cimg5.ibsrv.net/gimg/www.off...c8b2e82b2b.jpg
F1R
https://cimg4.ibsrv.net/gimg/www.off...057279c332.jpg
F2
What Eddie said regarding whipple sizing being very important, the same holds true for Prochargers, and roots blowers.
Putting a 14-71 blower on an engine thats only going to make 700HP , would be silly. You would have to spin it so slow, and it would be very inefficient. Likewise, putting a 6-71 on an engine that is trying to make 1100hp, would also be silly. The 1100HP engine would do much better with the 14-71, and the 700HP engine would do much better with the 6-71.
Prochargers aren't immune to parasitic losses like many think. Take a look at the results from the test steve morris did with a F1 and F2 procharger. Its easy to see why at 10lbs of boost, the smaller F1 took less power to turn. Roots blowers are similar. The higher the boost , the more power they take to turn. Big old COG belts , double key'd cranks, weren't meant for a guy running 8lbs of boost on pump gas in a boat. They were designed for guys running blown alcohol stuff, at high boost levels. Why? because a blown Alcohol setup would shred a serpentine belt in about 2 seconds at that level. That same roots, ran in a boat at 8psi, could run a 10 rib belt and be ok in most circumstances. Alot of the reasons many frown upon roots , stems from things they read or heard about. Things like the massive amounts of power they take to turn, the massive amounts of heat they generate, etc. While that is true in some cases, one must compare apples to apples. Comparing the heat generated, or parasitic loss from a 10-71 blower at 65% overdrive, to a 10-71 at 5% UNDERDRIVE, is not a fair assessment.
We run top dragster with a 540 ci and we had an bds 8-71 on it the last few years this year swiched to a 14-71 but we went 6.43 at 208 with hte 8-71 it was a high-helx blower. we spun it at 66%od the manifold temp was only 105*
66% overdrive with a 8-71 Hi Helix, on alcohol, and only 105* intake manifold temp. Not too shabby thanks to the alcohol.
SS496 03-13-2018 11:57 AM
Learn to read compressor maps. Then apply that logic to other "air movers" (mass flow rate, pressure ratio, compressor RPM, efficiency islands)...and everything starts explaining itself.
too bad compressor maps arent available (at least publicly) for other form types of air movers.
turbos230 03-19-2018 02:56 PM
Originally Posted by Young Performance (Post 4615386)
OK. I was trying to avoid typing a dissertation on how a supercharger works and why. I have done literally hundreds of engines with Whipples, so I'm confident of my suggestions on which blower you should use. Now I'll explain why.
Overkill in most aspects of engine building are a good thing. However, that's not necessarily true when dealing with a Whipple. Notice I didn't say supercharging. Overkill is fine with a roots blower.....spin it slow, don't build a ton of heat, blah blah blah. Not so with a Whipple. They want to spin. We regularly spin them up to 18000 rpm, or more. They don't like to spin slowly. If there is 1 downfall to a Whipple, it is that they have a tendency to pitch the air and fuel to one side at low rpm when the blower is spun to slowly. We've been able to mask some of it with Distributorless Ignition, but it's still present. In extreme cases, you can have 3.5-4 point AFR point differential from 1 bank to the other. The DIS is hot enough to burn most of the excess fuel that is pitched to that side. Other then that, there is nothing you can do. One side is on the verge of fouling the plugs and the other is super lean. Now, as soon as you start making some rpm, those issues go away. But, how much idling do you do? I'm sure a lot like everyone else, you do quite a bit.
Each of Whipple's blower setups have a window where they should be ran. You wouldn't use a 4L quadrotor to make 900 hp. Can it do it.....sure. But you won't be happy with the result. Just because it can do it doesn't mean it's right. I had 1 particular customer that bought a 2.3L quadrotor setup without consulting me. We were originally building around 900 hp. i told him that there was no way I could do that with that blower on 600 ci. He didn't want more then that because the boat had Bravo's. I put it on the dyno and made 1175 without even trying. He said "too much". I started taking boost out. I got it down to 1000 hp and it was TERRIBLE. Ended up at a little under 1100 hp. Once in the boat and idling, 1 side had AFR;s in the low 10's and the other in the high 13's. It was starting to put soot on the transom behind that one pipe on each engine. If I went any leaner, the engine would stumble going in gear. After a year of using it, we installed DIS. It was WAY better, but far from perfect. We still had at least 2 points from bank to bank at idle. Adding boost would have fixed it but he didn't want the added power. The correct supercharger would have prevented any of this from happening. You WILL run into the same issues with an 8.3L Whipple on a 600 ci engine making 1200 hp. Now, if you want to make 1300++, then that would be a good choice. Actually, the 5L would have been a good choice as well but they have discontinued it. It's the same blower as the 8.3, but spins the opposite rotor. Regardless, it's not available anymore.
They started building the larger single blowers to take the place of the quads. The single 4 and 4.5L were designed to replace the 2.3L quadrotor. They are much more compact, cheaper and easier to maintain. The 3.3L was easily replace by the 5L and 8.3L but is still available. I used to use the 2.3L quads pretty often. They were fantastic and made excellent power. We've made well over 1400 hp with them. However, once the 5L came out, we never used another 2.3L quad. The 5L was cheaper and MUCH easier and cheaper to maintain. They made more power then the 2.3 quad as well. The quads look extremely cool. I'll give them that. But now, the only quad I'll use is the 4L quad when I want to make stupid power. That's what we used on the engine that I posted above on youtube. That engine made almost 1800 hp when we spun it up. That pull was only to 7100 rpm and it made 1726 hp. We turn it well over 7500.
Now on to the intercooler. They are no different then the superchargers. Overkill is not a great thing. The FOAC is sooo efficient that it could cause issues. If you cool the intake charge too much, you can actually bring the fuel out of suspension. Liquid fuel doesn't burn. You must keep it atomized. If you live in northern climates, you will definitely have an issue in spring when the water is cold. Again, these aren't like your typical aluminum intercoolers. The CuNi that they are made off is one of the best suitable metals for heat transfer. They are certainly capable of pulling the IAT well below ambient air temp. There is no need for a FOAC on anything under 1500 hp. The MOAC is more then sufficient for what you want.
I've already said it twice, but I'll say it 1 more time. The 4L will easily make over 1200 hp on a 600 ci engine. It can make upward of 1300 hp if you really spin it. Not the ideal situation though. The 4.5L is the perfect fit if you want no less then 1200 hp, but the ability to make quite a bit more. With enough head and cam, you could make well over 1300 hp. Either of these would be great with the MOAC intercooler.
Hopefully this answers all of your questions. Take it for what it's worth but these recommendations came from many years of building engines and using Whipples. We use them on probably 95% of our SC engine builds so we are very familiar of their capabilities and their drawbacks. A lot of this I had to learn the hard way but you, and everyone else that takes the time to read it, gets it for free.
Eddie
Ok this is good information what I needed! The thing I was as thinking is if I have 10 liters of engine then the 8.3 would be better. Like I said this is new to me and there is too many things to learn and I dont have time to study everything.So I will get the 4.5 liter whipple yes?I dont have to get exactly 1200 hp ,any higher and I will not be complaining, I have #6 drives they can handle it.:ernaehrung004:
mcollinstn 03-23-2018 06:19 PM
#6 Drives are the best investment you can have..
But they still get queasy right around the numbers you are shooting at. Keep that in mind, and make sure your drives are happy and everything shimmed properly. Never hurts to go run them a little, immediately drain some lube out, and send it for analysis. Will let you know how much of its guts it's starting to gnaw on.
hogie roll 03-26-2018 03:49 PM
getrdunn 03-26-2018 07:19 PM
Wow... Like the weather... It's starting to heat up. Lol... Eddie I will be in touch via phone.
John
Young Performance 03-27-2018 11:48 AM
John
I look forward to it.
