525SC Rebuild Recomendations >
Old 03-14-2018 | 01:34 AM
JE SRP -3cc dome pistons should do the trick to get the compression ratio close to 8.25
Griff is offline
Old 03-14-2018 | 11:08 AM
From your response Griff, I'm assuming the best way to raise compression is increasing dome volume or piston height?
Here is JE's SRP pistons, I'm starting at 4.25" +.030" but what is the compression height & the stroke so I can pick the right one?
Mohavvalley is offline
Old 03-14-2018 | 11:27 AM
Anybody have any experience or opinions on Comp's 11-409-8 (224/[email protected]", 537/547, 113* LSA) with a -3CC domed piston at8.25-8.5:1?
Or would it be better to have comp custom grind something like a 731/741?
Old 03-14-2018 | 11:29 AM
Delete
Old 03-14-2018 | 12:52 PM
Yes, a piston change is the best way to change the CR in any significant way.
The 139477 has the same comp distance as the stock L2453 pistons
https://www.summitracing.com/parts/srp-139477-8
https://www.summitracing.com/parts/slp-l2453f30
Griff is offline
Old 03-14-2018 | 12:54 PM
If youre replacing pistons, i would go with an actual blower piston. Where the top ring is down further, better pins, etc. JE makes a forced induction flat top piston off the shelf for your application.
MILD THUNDER is offline
Old 03-14-2018 | 01:10 PM
I wouldnt bother with arp rod bolts. By the time you get done rebuilding/resizing those rods, with new bolts, youll be at almost the cost of a set of brand Eagle/scat H beams, or for a few bucks more, some molnar rods. And youll have a much better rod with a floating pin rather than a press fit. Ebay the old rods to some car guy who thinks the GM dimple rods were the best thing since sliced bread for 100 bucks.
the cam 79formula posted, works well in this combo.
upgrade the stock balancer. Powerbond makes a nice unit thats affordable.
if staying flat tappet, get the crower cam saver lifters with the oiling groove.
check the rear bearings in the blower , the seals leak and fuel gets in the rear oil reservoir.
Get a good valve job done on the heads. Worn guides lead to valves that dont seal well or transfer heat well. Inconel or not, they need to seal or they will burn.
a 30 deg backcut on the intake valves is cheap, and picks up a good amoubt of airflow at lower lifts
Old 03-14-2018 | 01:44 PM
F-2 Speedy's Avatar
I thought the pink rods were the cat's Azzz
F-2 Speedy is offline
Old 03-14-2018 | 02:32 PM
buddy i work with freaked out when i told him I gave a set of them away. He was like "those rods are amazing!" ...good rod , but cmon
Old 03-14-2018 | 06:36 PM
This guy needs some double hump heads and 3/4 race cams.
hogie roll is offline
