525SC Rebuild Recomendations
#51
Yeah I got a 7" lower with a 2.875" upper, if I go to 3.25" upper or a 6.5" lower that's put me about 2.09:1 to 2.15:1. And with my supper chiller boost reduction, I think I'd lucky to make 5lbs with that set up.
P.S. I'm looking for a automotive style keyed front shaft if someone has one laying around ( Blower is apart rebuilt and waiting to go back together
#52
They may have been 3.5" and 7" stock. I can't remember for sure, and thinking back, I think they were.
Either way, you are more than 2.15 overdriven.
Divide bottom diameter by top diameter and you are at 2.43:1
#53
i believe eve there were 2 different ratio / pulley combos a standard and a high altitude
#55
Ok doing the alighn-hone and need to know what main cap bolts to run, stock or ARP?
What's the max HP stock GM 4-bolt main bolts should be ran up to with a blower?
#57
Ok need to figure out windage tray options.
I plan on getting a "offshore" style 8 to 10qt oil pan, is it better to run a oem style windage tray bolted to the main caps or get a pan with a windage tray in it and eliminate the oem style one?
#60
Stock are 8qt pans and should be fine to 650-700 as long as you have a good oil cooler.
Same pan is used on the 700sci
Genuine Mercury & Mercruiser parts. 845668T PAN ASSY-OIL Genuine OEM Mercury Marine-Mercruiser part
